Vitara mk1 throttle Opener test
Posted: Sun May 08, 2016 11:57 pm
Hi I have been testing components on my SPI unit as I feel the car is a bit hesitant on acceleration and have found that when I change gear the revs don't drop as quickly as they should when the clutch is depressed. I am following the tests in the Haynes manual. For the throttle opener test it says I should disconnect the vacuum hose and expect to see rpm rise to 1700-1800. When I disconnect the hose and plug it then switch on, the rpm initially raises to about 2400 then quickly drops but it cycles from 1500 to 2000 rpm every few seconds rather than holding a steady rpm. The throttle opener works ok I have tested it with a vacuum pump. Do these symptoms indicate what my problem could be?
Thanks very much
Ade
Thanks very much
Ade
