Wiring up spot lights
Posted: Tue Oct 20, 2009 5:23 pm
by kgilmore
Hi, im wiring up my spot lights using the guide on the DIY section, however it doesn't tell you the wire for the beam, does anyone know what one it is, because it would save me going though the handfull of cables under the dash.
Also the flash beam uses a different cable does anyone know what that one is?
Cheers.
Re: Wiring up spot lights
Posted: Tue Oct 20, 2009 5:27 pm
by Henry
You mean the full beam?
Why dont you just tap into it on the headlights, is there any need to go under the dash?
Posted: Tue Oct 20, 2009 5:52 pm
by kgilmore
well i put the relay is under the dash, dont know why, but the only reason why I want it on the beam is so i can turn all my lights off by using one switch.
Just need to know the pattern of the cable ie. red with yellow strand.
Cheers.
Posted: Tue Oct 20, 2009 6:12 pm
by Henry
What sj have you got?
Posted: Tue Oct 20, 2009 6:29 pm
by kgilmore
413
