regretting 1.6 conversion
Posted: Sun May 22, 2016 8:44 pm
Hi everyone, thanks for all who replied to previous post. Since then, I have a bolted in 1.6 vit engine with an eBay special stage 1 upgraded clutch kit ( wouldn't advise purchasing due to poor manufacturing) fitted. A brand new 1.6 rad which leaks (another eBay spacial). And a few other more money than sense items (and I don't got much money, so whats that saying...)- please do excuse my attitude this evening, the reason for this is why I post.....
I cannot for the life of me get the engine running well, and believe it to be timing related, like it's out by half a tooth, however that works???
- I've fitted a brand new timing belt kit, and have ensured several times that I have fitted it correctly.
- I'm using 1.3 distributor, of which I have checked the generator assembly is working ok, and have again, several times, set and checked the ignition timing as best as possible.
- The SU is being used, with the BDL needle currently fitted, intentions to get a BFM.
- New leads, plugs dizzy cap and rotor is fitted, and have also tried the old just to see if any difference. None so new refitted.
- Coil has been tested too and is all good.
My problem seems to be that I require half a tooths adjustment on the timing. Can anyone relate to this mystery?
To try get it going better, I've played about with ignition timing, and even played about with the belt itself, but no matter how well and accurately it's set, always looks to be half a tooth out. Either one way or tother. DTI has been used to double check absolute TDC and like I say, double and triple checking has been carried out to try find what I'm doing wrong. Had the rocker cover off today to ensure valves are moving as they should be, and they seem good. The engine will fire up with a bit of messing about on the ignition timing but I cannot get it to run nicely, ie, will not pick up revs and is chucking out a great deal of unburnt fuel, ( dont put your bonnet in front of your home made side exit exuast when this happens).
So with this info, is anybody able to point me in the right direction to get to the bottom of this and start making some progess?
Unfortunately I know very little about the engine and its history, other than it apparantly done around 75,000 miles. I've had to braze the sump as had holes in it, and recall the vits' dizzy being set to quite an extreme when removed. Have had my brother with his advanced automotive engineering know how on it today with me, and its came to crying out for help still. He seems to think its firing at the wrong time with everything timing wise set correctly??? Could it be that I've set the timing as good as it gets and my issue is carb needle/fuel related? Should I have used the vits dizzy and never even removed it? Hell yes! I was a cheapskate and wanted to make use of spare leads and dizzy cap and rotor for 1.3. Is the low pressure facet type fuel pump the cause, either starving or overfuelling? the plugs dont look bad, but are a tad inconsistent between cylinders.
I do apologise for this long ass venting post, im sure I'll love it when she's working, if I can get her working...
