sj413 steering wheel
Ryebeck
Post by Ryebeck » Mon Aug 08, 2016 2:38 pm
anybody know if any other steering wheels , suzuki or not will bolt straight on to the sj spline ? im a big guy and looking to reduce the circumference of my sj steering wheel size but going down the momo adaptor and a flebay wheel is not an option as that puts the wheel out about 2" further towards the seat .. so any quick bolt on alternatives out there ??
[color=#FF0040][b][i]Getting there with some new Monster Truck Mods [/i][/b][/color]
SherwoodNash
Re: sj413 steering wheel
Post by SherwoodNash » Mon Aug 08, 2016 4:24 pm
I'm no expert but I'd guess the smaller the diameter the deeper the dish effect, thereby bringing the wheel closer to you again.
Here's a cheap Swift one that looks smaller diameter than the SJ's 15.5" that might fit your spline OK, or you could return it.
http://www.ebay.co.uk/itm/331917545625
Here's a flatter Carry one, again looks smaller diameter but can't return this one.
http://www.ebay.co.uk/itm/252483460932
r-nottz
Post by r-nottz » Mon Aug 08, 2016 7:25 pm
Get a slim line boss and non dished wheel
Post by dan_2k_uk » Mon Aug 08, 2016 10:45 pm
I know Vitara steering wheels are the same spline size but they are all pretty similar in size.
Ryebeck
Post by Ryebeck » Tue Aug 09, 2016 2:16 pm
cheers lads ill check em out
Post by Tramp » Tue Aug 09, 2016 3:32 pm
Old swift Gti wheel fits
Post by ScottieJ » Tue Aug 09, 2016 3:34 pm
The problem with smaller wheels is that they usually block the view of the speedo etc so keep that in mind. I'm pretty tall and I quite like the big standard wheel
SherwoodNash
Post by SherwoodNash » Tue Aug 09, 2016 4:44 pm
ScottieJ wrote:The problem with smaller wheels is that they usually block the view of the speedo etc so keep that in mind.
That's a very good point!
stevepsj413
Post by stevepsj413 » Tue Aug 09, 2016 7:57 pm
ScottieJ wrote:The problem with smaller wheels is that they usually block the view of the speedo etc so keep that in mind. I'm pretty tall and I quite like the big standard wheel
Yeah thats deffo an issue. Cant see the speedo with my mountney fitted, u can only see the center of the speedo needle, I just use the clock hand method, 9'oclock 20mph, 10'oclock 30mph, 11'oclock 40mph, etc etc.
Post by twiss » Wed Aug 10, 2016 6:39 am
You only need to see the speedo for cameras or if theres a police car behind though :P
