Getting used to my Vitara
Posted: Sat Nov 19, 2016 1:13 pm
by Sam the actor man
Hi
Just got my vit on the road, it was a present from my uncle, a '97 1600 with only 38k on the clock. Had to have a load of welding on the sills done and the rear wheel arch but hopefully it will last me a good few years yet.
The thing is when I drive home up a hill road, there is one adverse camber that occasionally the back end slips out on. I can catch it easily enough but it would be pain if there was something coming the other way. Is this something I just have to get used to and maybe ease off the accelerator at that bit or is this something I need to be worried about.
Also with the manual hub selectors, do both left and right both turn the same way ie clockwise as I look at them, or are they supposed to turn towards the front of the vehicle or the rear? (Does that make sense?)
Simon
Re: Getting used to my Vitara
Posted: Sat Nov 19, 2016 3:34 pm
by Darrell
Welcome to the forum. Little weight on the back end and some tyre brands including right foot
can make them a little tail happy. Yes both the hub lockers go the same way. If your not familiar with Suzuki 4wd don't put it in 4wd on the tarmac/grippy surface. That's the transfer box, hubs can be locked in whenever you choose.
Posted: Sat Nov 19, 2016 3:50 pm
Darrell wrote:Welcome to the forum. Little weight on the back end and some tyre brands including right foot
Thanks, much appreciated. I'd picked up that I'm not meant to be in 4wd on tarmac, only where there is less grip but couldn't understand the hub selector bit. Is there any benefit to having them locked or unlocked?
I'm probably only a month or so away from having to buy new tyres as it had been standing for a couple of years so the side walls are split slightly. So I'll have to work a couple of extra shifts next week and buy them early.
Just had to pay out for the welding as the sills were rotten as well, shame as first MOT guy said he'd never seen one this age with such a sound chassis and engine but apparently rusting sills is a Vitara thing
Simon
Posted: Sat Nov 19, 2016 4:08 pm
by ROBBIE
Hi
enjoy your vit
Posted: Sat Nov 19, 2016 5:48 pm
by Darrell
To save wear on the front drivetrain leave them unlocked until you go offroad. They are then ready as soon as you put it in 4wd. Don't wait until your stuck in a muddy hole
Posted: Sat Nov 19, 2016 6:18 pm
I always found with my samurai you could get a little bit more performance out of it with the hubs unlocked... not much but over a long distance you notice the fuel economy, and you will notice the top speed slight increase
Posted: Sun Nov 20, 2016 12:32 am
It's probably just the tyres. Old tyres go hard and don't trip as well and like to slide out, I used to have a vit with some old AT tyres on the back that were useless, it was fun "accidentally" going sideways everywhere
Posted: Mon Nov 21, 2016 8:16 pm
Thanks all. Great advice
Yep it's a bit of fun but could do without it on the way to work when I'm still half asleep lol
Posted: Wed Nov 30, 2016 8:38 pm
by Rhinoman
If they are the original Bridgestone HTs then they were very poor in the wet when they were new. You should make sure that the tyres aren't over-inflated as well 23psi is all they should be.
Posted: Thu Dec 01, 2016 10:46 am
by RickUK
The tyre pressures on the Vitara are critical,i run mine at the factory suggested 23psi all round and that is even with the 2ltr V6,i did try a higher setting but the Vit was all over the road,it hated it,but as soon as they had 23psi in it grips very well.
On my old Izusu Trooper i found it run better at 36psi but that was with the 2.8td heavy lump in it,so i tried using those settings on the Vitara,drastic mistake.
