No electrics and won't start - FIXED
combatkenz
Post by combatkenz » Tue Aug 29, 2017 4:25 pm
Hi guys,
My samurai won't start! Basically I took it out on some green lanes then stopped off turned it off and when I turned the key nothing happened! No electrics are working and when you turn the key still nothing works. I've tried jump leads and check the fuses under the dash still nothing!
I would really appreciate any help!
Re: Urgent help needed!
Post by Darrell » Tue Aug 29, 2017 7:07 pm
Have you checked the fuselink by battery ??
Post by Darrell » Tue Aug 29, 2017 7:11 pm
combatkenz
Post by combatkenz » Tue Aug 29, 2017 7:42 pm
Darrell wrote:Some info........... http://forum.suzukiclubuk.co.uk/vi ... =11&t=5983
Thank you! Would that stop any electrics from working?
Post by Darrell » Tue Aug 29, 2017 7:42 pm
Yes... all of them
combatkenz
Post by combatkenz » Tue Aug 29, 2017 8:30 pm
Am I right in saying I should still be able to jump start it to get it running??
Post by Darrell » Tue Aug 29, 2017 9:17 pm
Nope, power to starter motor but no power to starter solenoid/ignition circuit.
RickUK
Post by RickUK » Tue Aug 29, 2017 9:47 pm
Sounds like the fuse link has blown.
Deceased.
Current wheels.
combatkenz
Post by combatkenz » Tue Aug 29, 2017 9:53 pm
Darrell, Thank you for your help! Turned out to be the fuse link, the cable had snapped. I managed to press it together to get enough contact to start it.
Does anyone know where you can buy new ones from?
combatkenz
Post by combatkenz » Wed Aug 30, 2017 11:24 am
I managed to source one from a dealer so all good.
