Wiper motor not working
timwilks13
SCUK Website Padawan
Post by timwilks13 » Fri Jun 26, 2020 8:00 pm
My wipers have just stopped working entirely, I have checked the fuse which is fine, the jet motor works but the wiper motor does nothing.
Its the tin top so not easily accessible to check the motor, so what would be the first points of call before I start tearing the dash apart?
Re: Wiper motor not working
Post by ROBBIE » Fri Jun 26, 2020 11:05 pm
The spindles through the frame can seize
timwilks13
Post by timwilks13 » Fri Jun 26, 2020 11:16 pm
Ok cheers Robbie I'll have a look tomorrow. What's the fix for that then? Pull them off and WD or grease or something?
Post by ROBBIE » Sat Jun 27, 2020 8:46 am
Try spraying them with wd and letting it soak. Removing them was hard work on a soft top, going to be worse on a tin top
SherwoodNash
Post by SherwoodNash » Sat Jun 27, 2020 1:10 pm
Getting to that wiper motor would be my worst nightmare, hope the WD-40 works first!
Good luck 👍
1987 Suzuki SJ410 Van
timwilks13
Post by timwilks13 » Sat Jun 27, 2020 4:52 pm
Jobs a good un, just seized as you said Robbie, soaked in WD for a few hours, then ran the motor and helped it by hand, once they loosened a bit I attacked them with some PTFE spray and they're spot on thank!
Post by ROBBIE » Sun Jun 28, 2020 10:29 am
Nice one :thumbup:
