hi i'm a new member here,my name malie from brunei...
i've just bought suzuki sj410 got pic of it
plan to upgrade for offroading...btw my car still stock condition
got any tip what should do 1st thnx......sorry cant post pic to big dont knw how to reduce hehe
ok i solve it here the pic
13122009(002) Copy.jpg (40.57 KiB) Viewed 8263 times
first thing i did was get some good tyre's! Your sj is already very capable but a good set of mud boots you'll instantly see results! I run grizzly claws and think they're ace...much better than the colways i had on first...depends on you budget and terrain you planning to conquer!
chris
welcome to the club matey! thats a tidy little 410 you have there, no doubt give it a year or 2 and it will be a bit less standard
Mine started out as a standard 410, once upon a time
and i have plans to get rid of the soft tops rear and hatch the back, also hopefully complete the roll cage, get rid of the shackles........etc......
As you can see malie, theres plenty of mods you can do!
O and if you raise your sj stay away from shackles, they're a pian!(yes i know i have them but it was my mistake so dont do the same )
ur adivse was very helpful to me guy thanx...i've all ready change da timing belt...but nw i got problem while driving the engine stop run if i let go the gas pad..could it be the carb????.... (btw my English not that good )
Hi mate, Thats a nice looking SJ you got there, My advice, go out and enjoy before doing any mods. See what it can do and I think you will be suprised.
If you new to offroading I wouldnt advise going straight to a set of muds, mabye a set of all terrains and you will find you will start slipping along time before you get into a situation that could put you in danger etc etc. Then when you have the confidence and the skill got for a set of muds. With AT's you learn to find traction rather than rely on the tyres. this will make you a better offroad driver and even better with a set of muds
