wheel spacers
j and j
wheel spacers
Post by j and j » Thu May 06, 2010 9:24 pm
Going to fit some 31's,is it best to fit spacers or off-set rims to clear chassis?
Henry
Re: wheel spacers
Post by Henry » Thu May 06, 2010 9:28 pm
Depends what you can get hold off. I run spacers, have no problems, no issues or anything.
Rims would be better, but spacers are good.
But some think they are a death trap.. swings and roundabouts.
j and j
Re: wheel spacers
Post by j and j » Thu May 06, 2010 9:32 pm
That was quick! Only using them off road so not high speed if that makes any difference.
Re: wheel spacers
Post by Jordi » Thu May 06, 2010 9:36 pm
I've gone for off set rims and spacers, gives a good few extra inches of stability. If i could of got rims with a bigger off set i would have and done with out spacers tho. I couldn't get the wheels i wanted off set that far, and others where way too expensive for me.
Henry
Re: wheel spacers
Post by Henry » Thu May 06, 2010 9:44 pm
go for both if you can, lots of offset :twisted:
Re: wheel spacers
Post by Jordi » Thu May 06, 2010 10:18 pm
I think if i go any wider, it'll need fat ass stickers on it.
j and j
Re: wheel spacers
Post by j and j » Tue May 11, 2010 9:18 pm
henry-the-hoover wrote:go for both if you can, lots of offset :twisted:
Not sure if your joking or not! I race stockcars in my sparetime :?: and some drivers run up to 8inch offset but also do drive shafts on a regular basis! I was thinking about this problem on the sj.
Re: wheel spacers
Post by Tramp » Wed May 12, 2010 6:06 pm
I think competition limit is 28mm, I ran 32mm spacers for a while. but the main difference is what sort of spacers you run. The cast type are the cheaper ones, but I went for the more expensive machined ones (as I was running on the road and they are supposed to be heavier duty!)
If you go too wide with the spacers & offset you end up going through wheel bearings becuase of the extra stress, Personally I would go with either one or the other,
I think that bits 4 vits sell the spacers, http://www.bits4vits.co.uk/store/index.php
Re: wheel spacers
Post by ScottieJ » Thu May 13, 2010 2:13 pm
Just remember the more offset your wheels become the more strain there is on your wheel bearings and they will fail more often!
j and j
Re: wheel spacers
Post by j and j » Thu May 13, 2010 9:05 pm
Decided to go for modified rims which i sorted today. Got some part worn 31's to fit at the weekend and then get sorted for SPOA. :P
