Shoes
Sircharles2
Shoes
Post by Sircharles2 » Tue Dec 07, 2010 11:18 am
hi, doing brake shoes on the weekend. haven't done the before.
Do i need a pullers to get back hub off or will a hammer knock it off?
anything else I should be aware of?
Thanks Graham
Re: Shoes
Post by ScottieJ » Tue Dec 07, 2010 12:26 pm
It depends. I made a slide hammer to remove them and halfshafts as they can be stubborn sometimes. best thing to do is to leave the wheel on, undo the 4 bolts and kick the wheel off. :mrgreen:
Pugsley
Re: Shoes
Post by Pugsley » Tue Dec 07, 2010 11:42 pm
If you haven't done the job before you may want to take a photo (digital) of the brake layout once you have removed the drum. Print it for reference because it's easy to forget where the different springs go and how they are routed.
Sircharles2
Re: Shoes
Post by Sircharles2 » Wed Dec 08, 2010 10:17 am
will do, cheers thanks.
