Starters for sj 1.6 conversion
Posted: Wed Dec 08, 2010 11:05 pm
Always double check that the motor diameter is around 3", that fat 3.25" ones need grinding
Bosch skinny starter part number 0-001-112-032
Mitsubishi skinny starter m1t74583
DRS3045 This is a generic part number so it might take a few attempts before your local parts store gets a skinny one using it
QS1430
Alternatives.
Bear with me on this one, I want to double/triple check it's the right part number
I found this on my mates jap SJ 413 ...
it fits properly on a samurai gearbox as well.
Smaller than the skinny starters that are getting quite rare now...
Valeo D6RA13
This is the starter I originally started off with.
Get them new from here: http://www.woodauto.com/Unit.aspx?Man=VALEO&Ref=D6RA13
It looks very similar to the D6RA62, but can be told apart from it due to the different size housing although the motor itself and the solenoid are the same.
This starter had 9 teeth and will fit on a Suzuki.
You can see in the photos below how similar they are. The first photo shows my D6RA13 with the D6RA62 motor and solenoid.
The second picture shows the housing parts of both starters and how they differ.
D6RA62 housing on the left, D6RA13 housing on the right
D6RA62
This is fitted to quite a few different cars, so is easy to come by.
You do need to check the amount of teeth on the gear though, as some have 9 and some have 10.
They are fitted to:
OPEL Agila 1.2 01/2000 -
OPEL Astra F 1.4i 09/1991 01/1998
OPEL Astra F 1.6i 09/1991 01/1998
OPEL Astra G 1.2 16V 03/1998 -
OPEL Astra G 1.4 16V 03/1998 -
OPEL Astra G 1.6 16V 03/1998 -
OPEL Astra G 1.6 8V 03/1998 -
OPEL Corsa B 1.2 02/1993 01/2000
OPEL Corsa B 1.4 03/1993 01/2000
OPEL Corsa B 1.6 03/1993 01/2000
OPEL Corsa B 1.6i 16V 11/1994 01/2000
OPEL Corsa C 1.2 04/2000 -
OPEL Corsa C 1.4 16V 04/2000 -
OPEL Vectra A 1.4 09/1988 01/1994
OPEL Vectra A 1.6 01/1994 01/1995
OPEL Vectra B 1.6 16V 09/1995 -
OPEL Zafira 1.6 16V 03/1998 -
VAUXHALL Cavalier 09/1988 01/1994
There is another starter than basically shares all of the same components, except for the silver metal casing. The motor, solenoid and gears are the same.
These are normally about £30
I haven't tried it but you can get remanufactured cavalier one for £30!
http://cgi.ebay.co.uk/S715-VAUXHALL-NOV ... 5d2afd9dbb
D6RA 63
Ideally you need to get a starter that is a D6RA13 to begin with, but these have the correct amount of teeth and are good for spares.
They are fitted to:
RENAULT Laguna 2.0 16V 09/1999 01/2001
VOLVO S40 1.6 01/1997 -
VOLVO S40 1.8 09/1995 -
VOLVO S40 1.9 T4 05/1997 01/2000
VOLVO S40 2.0 01/1996
You can get them on Ebay for £40 roughly... cheaper from a motor factors or scrappy where you don't have to pay for delivery.
The good news is, if you find a cheap one with 10 teeth, you can get the gear for just under £15 and swap it
http://www.woodauto.com/Component.aspx?Ref=SDV38156
Easiest way to find them is on ebay, i.e. search for "vauxhall cavalier starter motor"
QS1430
Alternatives.
Valeo D6RA13
D6RA62
They are fitted to:
D6RA 63
They are fitted to:
