Anti roll bar???
Slinkyjim
Anti roll bar???
Post by Slinkyjim » Sat Oct 18, 2008 1:01 am
im lost on this one my sammy came with an anti roll bar but i want to take it off for more articulation but ive been told if i take it off then it will fail the mot shall i take it off after the mot and what will it handle like without it as it will be used as a daily driver too.
IF IN DOUBT GIMME A SHOUT
trotter
Re: Anti roll bar???
Post by trotter » Sat Oct 18, 2008 2:00 am
i dont think its a mot failure mine passed last year without it but then as with most mots it depends on the mood of the tester...
if you take it off just take it easy when cornering and you should be fine i've had no problems with mine
if in doubt, FLAT OUT!
bourneyo
Post by bourneyo » Sat Oct 18, 2008 11:51 am
Its a 5 min job to remove (provided the bolts havn't seized) and refit, jus keep it in the shed and if MOT man does have a problem refit it.
Dan 8-)
Post by dan_2k_uk » Sat Oct 18, 2008 1:05 pm
handles fine without it. i can do little drifts on really wet days without to much body roll. mine also went through the mot without it. :lol:
srcars
Post by srcars » Sat Oct 18, 2008 6:37 pm
Or cut the brackets off so mr MOT cant see something is missing.
urbanzook
Post by urbanzook » Sun Oct 19, 2008 10:36 am
mine passed mot with out. just expect more body roll slow own for sharp corners.
if i try an do dow nuts it lifts one wheel.
