Nikki carb cutting out on steep climbs
Jumpinjacks
Post by Jumpinjacks » Tue Apr 05, 2011 12:59 pm
Hi
I took my sj out last night for the first time since rebuilding the tbox and done some hill climbs. I have recently fitted a nikki carb which runs perfect normally, but it would cut out if I got stuck on a steep incline, but fine on a decline. Is there any sort of mod I can do to solve this problem ( float height etc )?
Thanks,
Adam.
Suzuki SJ 413 Samurai owner
Jumpinjacks
Re: Nikki carb cutting out on steep climbs
Post by Jumpinjacks » Thu Apr 07, 2011 7:19 pm
Anybody???
Post by Edweird » Thu Apr 07, 2011 8:21 pm
I don't think hardly anyone runs a Nikki. I know folks have run into the same problem with Webbers, and it was something about the spring and needle I think.
Post by twiss » Fri Apr 08, 2011 2:32 am
It's something to do with the float setting. Apparently with the webers you can adjust the float and it will work properly.
I think I might have found a web page about it when I was researching into carbs....
