Page 1 of 2
softer suspension
Posted: Sun Apr 17, 2011 7:41 am
by lightning
hi all
I would like to get my suspension a lot softer on my sj
How or what is the best way of doing it
Re: softer suspension
Posted: Sun Apr 17, 2011 9:52 am
by Henry
What suspension setup are you currently running?
Posted: Sun Apr 17, 2011 12:31 pm
by lightning
all standard
Posted: Sun Apr 17, 2011 5:13 pm
by Henry
I would go for some softer shocks then. Somehting like Procomp es1000?
Posted: Sun Apr 17, 2011 8:39 pm
by lightning
Henry wrote:I would go for some softer shocks then. Somehting like Procomp es1000?
will the Procomp es1000 help much
where the best place to get some
seen some e3000 will they do??
Posted: Mon Apr 18, 2011 1:44 pm
by Edweird
I think the 3000s are harder, designed for use with lift kits I think.
Posted: Mon Apr 18, 2011 1:50 pm
I had ES3000s on mine... have taken them off because they are so hard!!!
If you're racing on loose surface I'd imagine they'd be alright...
...but they are rubbish for road use!!! SO BUMPY!
Posted: Mon Apr 18, 2011 2:24 pm
Bedford rascal rear springs and rear sj springs up front
the problem with SJs is that the springs are too short to give a good ride, use longer springs at each end and you improve articulation and comfort
Posted: Mon Apr 18, 2011 7:21 pm
by lightning
ScottieJ wrote:Bedford rascal rear springs and rear sj springs up front
will leave the e3000 alone
Will have to look out for some Bedford rascal rear springs
dose any 1 know for some
Posted: Mon Apr 18, 2011 8:00 pm
by ROBBIE
coil conversion?
