New Owner From Staffs
charger
Post by charger » Tue Jun 28, 2011 11:21 am
Hello all I'm a new owner of an SJ 413 Samurai.
I also have a WJ anus that I have done a bit of off roading in but found the offroad parts like bumpers are very expensive so I stopped at a 2" lift & AT Tyres. Got the SJ so I could keep my anus in good condition & have a dedicated offroader. I plan on taking the SJ to my local pay & play to see how it does all stock. I live in Newcastle Under Lyme if any on else is anywhere near.
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
Re: New Owner From Staffs
Post by twiss » Tue Jun 28, 2011 1:29 pm
Hi charger,
Welcome to Suzuki Club UK! Glad to hear you've got yourself an SJ! :D
Are you planning on having the zook road legal? If not, I'm sure a anus will be able to tow an SJ on a trailer!
If you are looking for other members, check out the members map. There should be a link above for it, with a spinning globe next to it.
I think we're mostly down south at the minute
charger
Post by charger » Tue Jun 28, 2011 4:24 pm
Going to mod it but keep it street legal
Need help with mods what's cheapest way to lift will prop shaft be ok over 3" of lift what size tyres with stock & lift.
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Post by twiss » Tue Jun 28, 2011 4:30 pm
The cheapest way to lift is using lift shackles... but I will bet that none of our members will tell you to put them on!
They mess up your handling and ruin springs
The best cheap way off getting lift is using add-a-leaf springs.
They are an extra leaf that you put into your spring pack. It's a given that all SJ springs are probably much more flat than they should be, unless new springs have been fitted! Add a leaf will give you roughly 2" of lift.
You can do the whole vehicle for just over £100. If you're interested check out Llama 4x4 on our links page.
Dave from there is the nicest bloke ever so just phone him for a chat. It might take a while to get them from the states though.
If it's still not enough lift, you can add slightly extended shackles (no more than 1" and your springs/steering will be ok)
Just remember if you are lifting, you should also widen to retain stability. Getting some wheel spacers is the cheapest way.
You can either get them new from Bits 4 Vits, or get them from ebay
Post by ROBBIE » Tue Jun 28, 2011 8:01 pm
howdy :welcome: to the club. go add-a-leaf from llama as twiss said or get lift springs from the same place
and we need pics ;)
dominic
Post by dominic » Tue Jun 28, 2011 8:55 pm
Dom
:smokin:
Currently Drive
SJ 410 Q 1985 (GREEN)
VITARA GL+ 2017 (SILVER)
Post by ScottieJ » Tue Jun 28, 2011 11:37 pm
:welcome: to :S:cuk matey :doublethumbs:
Well because it's me :mrgreen: and your saying it's just got to be a road legal toy that you can play in and not worry about too much.
I'm gonna ask can you weld? if so pull out the angle grinder and get cutting :mrgreen:,do a virtual lift and don't run any lift,(no shocks, propspacers or longer brakelines needed :thumbup:) just make sure you have some good leaf springs. add some 31x10.50 tyres on 8" wide rims and a rocklobster transfer box off rockwatt (you'll need a 410 and 413 tbox) to lower the gearing and you'll have a bloody capable and pretty reliable little SJ :mrgreen:
That's what I would do if I was to buy another one
this is what mine was like with virtual lift, a 2" spring lift and 33s. 33s brake more stuff than 31s though :lol:
Newtomud
Post by Newtomud » Tue Jun 28, 2011 11:43 pm
:redtin: Hi and :welcome: From Wolverhampton
charger
Post by charger » Wed Jun 29, 2011 8:13 am
Thanks people
How does the SJ do stock off road
Will have a look at the Zuki section on llama, I know Dave bought a diff guard of him for the WJ
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Post by twiss » Wed Jun 29, 2011 9:05 am
Stock SJs are really good off road actually!
For ages I had mine standard with a set of 195 (regular size) mud tyres on it. It was awesome like that!
The problem arises when you get to some ruts dug by someone with bigger tyres... then you will ground out on your diffs/axles
