Hello form Ireland
Hello form Ireland
Hello all been lurking on here for a while so took the plunge and joined up.
here are a few shots of my truck
There are a bunch of us here into zooks and most are total offroad trucks
K
K
Re: Hello form Ireland
to club nice truck love it
to the club.
Hi and Nice pics
Hi Guys thanks for the welcome and comments, we bought the zook to see how cheaply we could make a capable off roader capable of taking on the larger challenge trucks, and this little green truck is a giant killer, Has anyone any experience of fitting Vitara 4.88/5.12 diffs to their trucks and how does this compare to a rocklobster xfer box conversion, obviously the diffs is a cheaper conversion.
to :S:cuk
that's a well used and abused tintop
do the 33s in the second picture fit without rubbing? looks a bit tight
A bit tight in fairness, but as we need to address the gearing first, its running on 235X75X15's at the moment, A friend of mine made a set of wheel spacers which bolt to the suzuki axles and take landrover rims so we have a big choice of tyres here.
anyone any advice on the diff question above?
K
K
Hi matey!
I have just added a write up to the DIY section ^^^^ it needs a few more details added to it regarding setting up the bearing preloads and backlash but it should give you a good idea on where to start.
It's a good conversion for running 33s with standard tbox gears and should work well. not sure if I would advise it if you would be using your sj on road and had tyres smaller than 33" though.
