Sj 413 Box same as Samurai?
africanbiker
Post by africanbiker » Wed Sep 07, 2011 9:51 pm
Hi i have a SJ 413 (1986) with a 5 speed box, will a Samurai box fit straight on? Mine has a bad bearing and just looking to replace the box. I have been offered a Samurai one.
Re: Sj 413 Box same as Samurai?
Post by turbo-tom » Wed Sep 07, 2011 9:55 pm
i cant help you im afraid as im waiting for that answer :lol: , but im pretty sure there the same the look it anyway :lol: but double check with someone else too ;)
Post by ScottieJ » Wed Sep 07, 2011 10:16 pm
Yes they are exactly the same :thumbup:
africanbiker
Post by africanbiker » Wed Sep 07, 2011 10:17 pm
Thanks. :cowboy::
Post by Edweird » Wed Sep 07, 2011 10:53 pm
I think there's a slight difference in some ratios, but other than that
spanish sammy
Post by spanish sammy » Thu Sep 08, 2011 10:59 pm
sorry to bug you guys ..is the 410 samurai on a 1990 gear box different to the 413 ?
Post by ScottieJ » Thu Sep 08, 2011 11:06 pm
410 samurai? They don't exist do they?
The gearbox for the 1.0l engine has a smaller bellhousing and won't fit the 1.3l
spanish sammy
Post by spanish sammy » Fri Sep 09, 2011 5:21 am
Hey i have a 1.0 ltr samurai here in spain 5 speed first registered in 1994 but on the inlet manifold it says 89 ..its just im getting confused with all the 413 410 samurai sj its all a mish mash to me and if the 5 speed fitted is the same as a 413 i wont need to change it just get an adaptor plate..im thinking i have the result of useing up whats left in the factory maybe??
Post by ScottieJ » Fri Sep 09, 2011 9:21 am
Interesting, well as far as I'm aware all the 1.0ls will use the same gearbox and they are different to the 1.3 gearboxes, I don't think there is any way to make the 1.0 gearbox work with the 1.3 or 1.6 as the bellhousing is physically too small for the 1.3flywheel and that's what you'll be using for the 1.6 conversion.
I'm intrigued now, I wonder if the 1.0 samurais use the wider samurai axles rather than the narrow 410 and 413 axles? Could you post some pics up of your sj please :brows:
Post by Edweird » Fri Sep 09, 2011 11:40 am
Sure it's not a 1.0 litre Santana?
