wiring in ford altenater
Hi all, on the devil vitara engine iv just brought and fitted to my sj there has been a higher voltaged ford altenater fitted. Theres 3 terminals on it. Any ideas or experience on the best way to wire it up.
Re: wiring in ford altenater
You got a photo of the connections and are there any markings on each connection.
Ill get a decent pic and note down any marking in the morning and post em up... Cheers bud
Just uploading some pics now, Two larger terminals of the 2 one says B+ one smaller terminal which says D+
P.s. sorted the timing and she now runs, Thanks for your help.
Just need to figure the cooling plumbing and she should be sorted
cheers
cheers
Ok so iv now sat down and looked at it and figured the 2 larger terminals are battery +ve and the smaller terminal is for the dash light... Any hints to what colour the dash light wire is??
P.s correct me if im wrong lol
thanks
thanks
White and red.Any hints to what colour the dash light wire is??
Thank you!!
Yeah I'd say that sounds right looking at the pics.st3f4n wrote:Ok so iv now sat down and looked at it and figured the 2 larger terminals are battery +ve and the smaller terminal is for the dash light... Any hints to what colour the dash light wire is??
thanks
Any ideas where the Black with white trace wire would go??
carb solenoid and ignition coil.
