Hi, I have just hot my 1.6L carb vitara engine up and running in my SJ, however i need to replace the inlet manifold gasket before it can go anywhere, I have used the 1.3L SJ manifold as I already had a webber carb and everything setup on it, so i was wondering what gasket I should use?
Thanks,
Dan
1.6 conversion inlet manifold gasket
- Russ24
- Can I have a tow
Re: 1.6 conversion inlet manifold gasket
i put a 1.6 vitty lump in mine. used the same inlet manifold. as i didnt detach SU carb.
used SJ 1.3 inlet manifold gasket. no problems.
Ok thats great, thanks for the help
In the kit below would is that the top or bottom inlet gasket?
http://www.ebay.co.uk/itm/SUZUKI-SJ413- ... 1c088a6bbe
The top one looks like a 1.3 gasket i fitted to a friends the other day. The lower one is a 1.6 obe but i guess either will fit. The studs and holes are all in the same place and the difference in the size of tge ports is less than a mill.
Dan
Dan
- Russ24
- Can I have a tow
i used the top one. as its slightly thicker.dan_2k_uk wrote:The top one looks like a 1.3 gasket i fitted to a friends the other day. The lower one is a 1.6 obe but i guess either will fit. The studs and holes are all in the same place and the difference in the size of tge ports is less than a mill.
Dan
as i had the other one on when i fitted it to the previous engine.. it failed rather quickly on its own.
top definitly
Ok thanks for the replies
did your ilet manifold bolt straight on? mines touching the fuel pump!?
