Its Just so S...L....O....W!!!!! Help please
hey guys,
I bought a 413 sammie with a webber carb on it, it feels very slow and doesnt seem to have any torque, like at all, it was like it when i bought it but now im thinking its not normal, i can not get more than 50mph anywhere and going up a light hill i may even need 3rd gear!!
Any advise what i can try to get some more power from it?
Thanks
Mike
Thanks
Mike
- turbo-tom
Re: Its Just so S...L....O....W!!!!! Help please
try given it a good service and clean up , that might help it?
yeah sorry i meant the carb but if you service the engine aswell that wont harm it should help it anything thing
its had oil and filter change, im going to do plugs and leads tomorrow, see how that goes, i hope it helps
I would also have a look at your rotor arm and distributor cap, they can be just as important as plugs and leads
Otherwise, the carb might not be tuned properly if its been fitted by some random person!
- Edweird
First thing I'd do is make sure it's sparking properly, then I'd git the carb a service and tune up.
Check the cam timing. Also check the the distributor drive gear if its worn then you will be losing timing which would explain your lack of power..
Ive just bought a SJ414 and am too having similar experiences. Its also got a Weber fitted, and on the journey home it'd struggle to hit 60mph, (It does have larger tyres mind).
Ive since reset the carb idle mixture and speed following the official Weber fitting instructions found on here, and it seems to start alot better than before, the plugs were a little black and it was definately running rich.
Im planning on doing the plugs/leads/dizzy cap and rotor arm soon.
As I've not owned one before its hard to tell how quickly it should pull through the rev range and what is classed as "normal" (it may be because Im used to a Clio 172 and its fast revving engine
well just remember guys, stock the 1.3 had 64ish bhp + larger tyres than your average car so it's never going to have sports car performance and acceleration
- Highlander
- Can I have a tow
Thats not a phrase I've ever heard mentioned before when talking about SJ'schris71920 wrote:how quickly it should pull through the rev range
They are VERY slow compared to more modern stuff
Also a fwd car has the diff in the gearbox and that pretty much directly drives the wheels, there's a transferbox in between the gearbox and diffs to steal a bit more power from the engine in an SJ.
