Steering Damper Installation help
I just received my rough country steering damper kit, the kits never being fitted but 2nd hand and comes with no instructions. Could any of you point me in right direction as this is my first sj. Thanks Andy
Re: Steering Damper Installation help
Heres a picture of mine. Might be some help to you, the end that you cant see in the picture is just clamped on to the axle.
Right, couldn't find any instructions for rough country. I did however find some instruction for a similar damper only a different make. I robbed the pic and text, then altered a few bit (American spelling & left hand drive). Hopefully it reads correct now. Sorry, took me a while
- Steering damper fitment.jpg (221.85 KiB) Viewed 10463 times
While I've been farting around doing that, Ferris has added a pic
Now enhanced the light on it
- IMG_1488.jpg (93.91 KiB) Viewed 10462 times
looks simple enough, the N/S end away from the piston what dose it attach to
Gotta bracket that goes round the axle by a u bolt if I remember correctly, the other is on the steering bar as shown
ok thanks guys ill have a bash tomorrow
Just be aware with these...
I've been refused an MOT before because one end of the steering damper is supposed to be attached to the chassis
If they try to say this just tell them to look at a rangerover classic. The non steering link end of the damper attaches to a bracket bolted to the front diff as standard.twiss wrote:Just be aware with these...
