Steering Stabilizer?
Posted: Fri May 04, 2012 2:31 pm
by lifeisshort
Hi All,
I have a question which may be obvious but im a newbie to my Sammy.
I have lifted the sammy 2" and i only just managed to get the steering stabilizer (pictured) back on.
First what does this do? and do i need it?
ps soon to do a power steering conversion from a jimny aswell. do i keep the steering dampner on after fitting power steering?
thanks
Re: Steering Stabilizer?
Posted: Fri May 04, 2012 4:47 pm
by Edweird
Unless I am mistaken, that's an the anti-roll bar. It helps keep your truck the right way up and stop it from rolling in corners. If you're off-roading though, it's probably better leaving it off, as it limits your flex.
Posted: Fri May 04, 2012 8:13 pm
by ROBBIE
took mine off and threw it away
you get better flex without
Posted: Fri May 04, 2012 8:51 pm
by trotter
^^ likewise
its an anti roll bar
Posted: Fri May 04, 2012 10:01 pm
by dunnin21
do you need this for a mot
Posted: Fri May 04, 2012 10:31 pm
by Darrell
I keep mine on to help me throw it around corners and surprise the boy racers sat on my ass.
Posted: Fri May 04, 2012 10:38 pm
by Darrell
dunnin21 wrote:do you need this for a mot
Bit of a grey area, but most MOT stations will let it go as long as its all removed IE all brackets etc
Basically if it or any of it is there it has to be in good working condition.
Posted: Fri May 04, 2012 10:50 pm
by Darrell
thanks
If this was done with the vehicle level it should fit easily, but if you did it with either side jacked up it would fight you.
