power steering belt
ebooksgti
power steering belt
Post by ebooksgti » Sat Dec 29, 2012 9:16 am
How do I replace this as mine snapped do I have to undo the 3 bolts holding the pump in place ??
Re: power steering belt
Post by ScottieJ » Sat Dec 29, 2012 9:46 am
There should be an adjuster bolt that you loosen to move the pump, it's behind the pulley so you need to access it via one of the holes in the pulley.
I use Goodyear gatorback 4pk0813g belts for both my alternator and p/s belts.
