vitara water
vitara water
Any tips on getting water out of car after going through deep fords ??
Re: vitara water
The floor bungs in the foot wells
Re: vitara water
On top gear they shoot the floor
Re: vitara water
Tip it onto it's side?
On a serious note there should be floor bungs under the carpets like Robbie said
Re: vitara water
Ok i didnt see any bungs will av a look def gotta remove carpet now do i have to remove seats for this
Re: vitara water
if you want to remove carpet all in 1 piece you will need to remove seats & center console
should be a bung in each footwell front & rear
Re: vitara water
and if you cant be bothered to remove seats (like myself) drill a small hole straight through the carpet and the floor, then leave it a little while?
