steering damper
dandan
steering damper
Post by dandan » Mon Jan 21, 2013 10:22 pm
hi all just a quick 1 whats the difference between procomp, Rough Country need to buy 1. there the same price so just wondered befor i bort 1
Re: steering damper
Post by Darrell » Mon Jan 21, 2013 10:35 pm
I have know idea if they have different damping rates ????
But if you have standard/slightly oversize wheels you could just replace the original unit if it's knackered.
Steering dampers.jpg (45.54 KiB) Viewed 4874 times
SJ OEM damper.JPG (12.77 KiB) Viewed 4874 times
http://www.jimnybits.co.uk/shop/sj-/-sa ... d_619.html
Re: steering damper
Post by Jordi » Mon Jan 21, 2013 10:37 pm
Not a lot from what i've seen. To the point they are pretty much identical.
I've got the rough country damper. Seems fine. Been on 3+ years and hasn't shown any signs of wear or leaks.
dandan
Re: steering damper
Post by dandan » Mon Jan 21, 2013 10:43 pm
i will put up rated 1 on as have the bigger wheels spoa an bigger spings an shackles,an r just flip a coin on it then i guess :)
Re: steering damper
Post by Jordi » Mon Jan 21, 2013 10:45 pm
Sounds like a good enough idea. I just ended up with rough country as i bought a boat load of gear off llama and thats the ones he stocks.
dandan
Re: steering damper
Post by dandan » Mon Jan 21, 2013 10:49 pm
probly wil go with the rough country as i got me springs off llama , nice quick delivery no messing bout
