SU carb fuel leak problem??
Posted: Tue Mar 26, 2013 4:57 pm
Hello folks
Right finally got around to fitting my SU Hiff 44 carb on my SJ 413. Blanked everything off that i should etc..
I turned the key a it rang... then i turn the engine off, to see quite alot of fuel running out where the air filter goes. Any ideas as to why im getting fuel running out from the air filter should be?
Cheers folks
Cheers folks
