Santana crank vents Do I blow them Up or Down
npjrogers@btinternet.com
Post by npjrogers@btinternet.com » Sun Apr 07, 2013 6:27 pm
Santana Vit with 8v efi. Now with everyones help I have the sump off. Since there was so much crud in the valve cover, now cleaned out, and there was evidence of some in the sump, now cleaned out, can you help please! Do I push from the crank case up the oil holes or do I remove the valve cover again and blow any crud down before I put the sump back?
Nick
Belfast
Re: Santana crank vents Do I blow them Up or Down
Post by ROBBIE » Sun Apr 07, 2013 7:33 pm
I would take the rocker cover off and poke something down from the top
