should I remove these?
Richie
Post by Richie » Tue May 21, 2013 11:14 am
To get more upwards flex should I remove these brackets on the front springs or would they be to weak? They are the rear springs but fitted to the front.
Richie
Re: should I remove these?
Post by Richie » Tue May 21, 2013 11:18 am
These brackets
Post by ScottieJ » Tue May 21, 2013 11:41 am
Yes you can remove them but you might get a bit more axle wrap, they shouldn't make any difference to up travel though as you should really set your bumpstops at the point the springs are flat to avoid over flexing them anyway.
Richie
Post by Richie » Tue May 21, 2013 1:32 pm
Sry I ment down travel. Would that improve the articulation and safely let the wheel drop down further or over bend yhe springs?
