HELP!!!Camber correction after 2"lift fitted
I apologise if this has been done before I couldn't find a thread. I have recently fitted a 2" lift to my Vitara I have also fitted rear axle drop bracket, prop spacer,front diff drop brackets. It is sitting on 235/75/15 mud tyres I have also fitted camber correction bolts to the top of my struts but they seem to have made no difference. Both wheels are sticking out at the top(positive camber?)I have seen various ideas about redrilling holes yet there appears no room to redrill or welding on plates but I cannot weld. I can unbolt old and rebolt new but am no mechanic. Any help much appreciated.
Re: HELP!!!Camber correction after 2"lift fitted
I think you are supposed to use camber correction wedges somewhere in the suspension. I'm not entirely sure, so wait for some more knowledgeable people to reply
should have made myself clearer cam bolts were fitted instead of the top pinch bolt on the bottom of the strut Sorry for any confusion
fit a second pair of camber bolts in the bottom bolt of the strut
