Rear brake problems. SORTED!!!!!
Post by andyrew » Tue Aug 27, 2013 11:55 pm
Flipping lwb brakes wont work.
Tested everything.
Deleted bias valve
Swapped hoses over tried old rubber hose too
Swapped calipers over both okay
Bled with calipers up top
Fitted another master and servo ( cheers jordi)
Clamped off rear feed flexi hose from wing to chassis front brakes working fine good solid pedal
Blanked off one side of axle t piece . Drivers rear good solid pedal
Blank other side of t piece and Try with Rear passenger and it just lets pedal to the floor
So im left with the t peice or copper pipe being at fault which makes no sense.
will try again tomorrow. Im heading home
:S
Ladaman
Re: Ahhhhhhhhhhhhh!!!!!!!!
Post by Ladaman » Wed Aug 28, 2013 12:21 am
Sounds like a long frustrating day.
Good idea to go home. Hopefully you will see the obvious mistake straight away next time you look at it, and think what a ****.
Good luck.
Post by Edweird » Wed Aug 28, 2013 12:39 am
You sure the servo is working? Duff connection, vacuum leak or something? Sounds like a dead servo to me at least.
suzukisteve
Re: Rear brake problems. Loosing the will
Post by suzukisteve » Wed Aug 28, 2013 8:03 am
as ladaman said andy, some times you jus gotta walk away and come back to it later to be able to see the problem. hope you get it sorted bud
pickle power!
Post by ScottieJ » Wed Aug 28, 2013 9:01 am
Discs or drums on the rear?
Post by andyrew » Wed Aug 28, 2013 11:33 am
Converted to discs.
Should have kept the flipping drums :hahaha:
Rhinoman
Post by Rhinoman » Wed Aug 28, 2013 9:30 pm
andyrew wrote:Converted to discs.
My rear disc conversion went in the skip and I went back to drums.
suzukisteve
Post by suzukisteve » Fri Aug 30, 2013 8:02 am
how are you getting on with this andy? managed to sort it ok?
pickle power!
4x4rick
Post by 4x4rick » Fri Aug 30, 2013 12:19 pm
andyrew wrote:Flipping lwb brakes wont work.
Tested everything.
Deleted bias valve
:S
Andy... I have braided hoses across the rear axle a good t/pipe
will bring along with me also got the servo if u fancy swapping stuff around to eliminate the one fitted
Post by Jordi » Fri Aug 30, 2013 4:18 pm
Tested everything.
Deleted bias valve
:S
He's on the second servo and master cylinder now.
