Page 1 of 2
flat springs
Posted: Wed Aug 28, 2013 8:35 am
by suzukisteve
I know this has been asked a million times before but I can't decide what to do
my front leaf springs have seen better days, I can get some new standard ones for about 60 odd quid plus vat each. this is a bit pricey for me and all things going to plan I may have just brought a flat with the missus!
whats gonna be the cheapest option for me to do in everyones opinion?
they are almost inverted now
Re: flat springs
Posted: Wed Aug 28, 2013 9:34 am
Buy some 1.5-2" rear lift springs and do a rears up front conversion
Re: flat springs
Posted: Wed Aug 28, 2013 9:45 am
As said. RUF. Only needs one set of springs buying and will give a lot more flex up front.
Re: flat springs
Posted: Wed Aug 28, 2013 10:09 am
by suzukisteve
okie dokie. just gotta find some rascal rears then. is there much modification required to fit em? or is its pretty much a bolt on conversion?
Re: flat springs
Posted: Wed Aug 28, 2013 10:13 am
by suzukisteve
or can I use suzuki rears?
Re: flat springs
Posted: Wed Aug 28, 2013 10:29 am
You need your rear SJ springs to fit to the front. As they are longer it requires reloacted front shackles. Something similar to Scotties front YJ mounts.
To lift the rear you can fit rascal springs but if you can afford it i'd recommend a set of propper lift springs like Llama.
Re: flat springs
Posted: Wed Aug 28, 2013 11:22 am
by suzukisteve
I shall have a look see what I can find
Re: flat springs
Posted: Fri Aug 30, 2013 10:31 am
by ROBBIE
Cheap add-a-leaf. BUT dont do it
Re: flat springs
Posted: Fri Aug 30, 2013 11:25 am
by suzukisteve
yeah I was originally thinking that but it'll just make the ride absolutely solid and I need a bit of flex! gonna have to wait a lil while as it would seem that we've just brought a flat
complete with a man shed I might add!
Re: flat springs
Posted: Fri Aug 30, 2013 11:38 am
Congrats bud, more for the man shed than the flat.
