Steering Issue
- TomBod08
Steering Issue
So I am finally seeing progress with my zuk! All my suspension is now sorted with extended shackles and bump stops in place, and I've just fitted the new drop arm (which was a pain in the arse). But the only problem i have now it the steering slightly off centre, can i just take the steering wheel off and adjust it so it sits straight or do i have to take the drop arm off again and re position it? Bearing in mind i do get full steering lock.
One life. Live it....With a Suzuki
Re: Steering Issue
You can take steering wheel of and rotate it. Or undo the steering coloumn on the bulkhead just next to the battery.
- TomBod08
Re: Steering Issue
Thank god for that haha, saves messing around down there again. Cheers man.
