Hard top Query
tchettle
Hard top Query
Post by tchettle » Mon Nov 04, 2013 12:45 pm
Im posting on behalf of my son.
His sj has a soft top and is v Cold as the heater is somewhat poor.
He wants to fit a Hard top to it and thinks that you can get glass panels across the drivers and passenger and then fit a hard top across the back, Like a freelander.
I cant find any like this, is it possible to to do or retrofit a hard top.
Is the heater virtually useless or have a we a problem, the heater in my 1960's series land rover was more effective, i cant helpt think its a bit faulty.
Thanks for any help
Tim
Re: Hard top Query
Post by ScottieJ » Mon Nov 04, 2013 12:58 pm
Chances are that the heater matrix is full of mud and leaves so might be worth removing it for a clean, this does involve practically removing the dash though.
There's a hardtop on ebay at the moment.
http://www.ebay.co.uk/itm/Suzuki-SJ413- ... 3386df373c
My SJ is a soft top and I've never found it cold once the heater has warmed up so might be worth trying to clean the matrix.
tchettle
Re: Hard top Query
Post by tchettle » Mon Nov 04, 2013 3:14 pm
Ok thanks i will have a look at the heater matrix, It sounds like there is something wrong with it then
ScottieJ wrote:Chances are that the heater matrix is full of mud and leaves so might be worth removing it for a clean, this does involve practically removing the dash though.
Airinissima
Re: Hard top Query
Post by Airinissima » Mon Nov 04, 2013 11:23 pm
It isn't possible. The heater of the SJ/sammy comes directly from hell, with only 2 temperature settings: hot and very hot.
During hardest winters, even with the soft top, I have to switch the heater on and off every few minutes, to avoid boiling.
Rust is lighter than carbon fibre
Re: Hard top Query
Post by Edweird » Mon Nov 04, 2013 11:24 pm
Airinissima wrote:It isn't possible. The heater of the SJ/sammy comes directly from hell, with only 2 temperature settings: hot and very hot.
Mine is the opposite. My engine never gets properly hot so I avoid using the heater if possible, though in cold weather I have to to keep the windows clear.
Re: Hard top Query
Post by donkeychomp » Mon Nov 04, 2013 11:30 pm
Slightly different climate in Italy and if the zook has never been offroad the heater probably isn't clogged up with mud etc!
Airinissima
Re: Hard top Query
Post by Airinissima » Mon Nov 04, 2013 11:31 pm
maybe is a problem on right-driver models ^__^
here in Italy the sammy's heater is almost a mythic moster: my friends always asks me if my zuki is a regular car ..or an oven-on-wheels!
I must say that we seldom go under -5/-6°C...
EDIT: we posted the same time
Re: Hard top Query
Post by ScottieJ » Mon Nov 04, 2013 11:53 pm
There's something not right there then Ed, have you tested thermostat? Might not be fully closing.
Re: Hard top Query
Post by twiss » Tue Nov 05, 2013 11:21 am
Everyone seems to have random heater temps, or have to have their heater on when its hot!
I don't know how but the cooling system seems to work fine on my zook! That's one thing at least!
Re: Hard top Query
Post by Jordi » Tue Nov 05, 2013 2:27 pm
twiss wrote:Everyone seems to have random heater temps, or have to have their heater on when its hot!
Mines working spot on now. It warmed up a bit off road the other week but nothing to write home about.
I do need to clean it out though, the blast of shredded dried leaves everytime I turn the fan on is annoying.
