Newbie with SJ problems :)
Hilly
Post by Hilly » Tue Nov 12, 2013 11:03 am
Hi there ,, I'm new to all this so was hoping for some info on some bits to do with an SJ 413 that I've just bought if possible ??
It has a 1600 vitara engine fitted with like a gold coloured adaptor plate between the gear box and the engine , I bought it as a none runner as the stater motor was not fitted as there was a problem with it !? I've tested the starter and it seems to be fine but I can see where it's been hitting the flywheel past the ring gear teeth ?? And when it does crank over it cranks very slow as if its binding ?? It's a H reg so I think 90/91 year I belive the starter if from the original sj engine !?
If anyone has any ideas or info on what I need to do to solve this problem it would be greatfully received ?! Thanks in advance , Luke !!
Re: Newbie with SJ problems :)
Post by twiss » Tue Nov 12, 2013 11:07 am
First off welcome to the forum! :)
Do you have a pic of the starter motor you could post here? There are a few different types to it may help to know which one you have
1.6 conversion starters can be a pain at the best of times! (personal experience)
Hilly
Post by Hilly » Tue Nov 12, 2013 11:48 am
Just tried to post a pic but can't seem to get it to work ?
Post by twiss » Tue Nov 12, 2013 12:01 pm
Once you have a pic on your PC, underneath where you write the post is the "Upload attachment" section... hit the "Choose..." button and find the pic... then when done click on "Add the File"
If you are using the reply box at the bottom of the page you will need to use the full editor... Theres a button for it under the typing area
Hilly
Post by Hilly » Tue Nov 12, 2013 9:47 pm
tested it on the bench and it seems fine ?
Hilly
Post by Hilly » Tue Nov 12, 2013 9:53 pm
Marks on the flywheel ,, ? as if the teeth are going to far and fouling the ring gear some how ? Im wondering if there is a spacer missing of some sort ? Any help would be great thanks ! :S :er:
dazerede
Post by dazerede » Tue Nov 12, 2013 10:03 pm
Yr looks like it is going to far have I tried spacing it out a little bit
4” calmini lift kit :)
Hilly
Post by Hilly » Tue Nov 12, 2013 10:15 pm
ive tried spacing it out a little but seemed to make a funny noise once the solenoid had thrown in ?
Is this adaptor plate normal ? is this a set up that is used ?
Rhinoman
Post by Rhinoman » Tue Nov 12, 2013 10:32 pm
Its quite normal to use an adapter plate, the quality of them can vary though.
Post by Darrell » Tue Nov 12, 2013 10:39 pm
All the adaptor plates I've seen have been thin, so I'm not sure what you have there.
When the starter is bolted up is there still clearance between the starter body and the engine block.
I think that looks like the skinny starter though.
I assume when people do this conversion (using an adaptor plate) they do away with the thin standard plate fitted :er:
A couple more pics of your plate may be helpful (wider shot).
1300 block.gif (46.81 KiB) Viewed 6086 times
1600 block.gif (48.19 KiB) Viewed 6086 times
