Page 1 of 2
brake pads help please
Posted: Sun Nov 17, 2013 4:58 pm
by minibreaker
hi when i order my brake pads will i get all the little metal retaining clips that fit to the caliper as one of my calipers has no clips. these clips are thin metal that hold the pads in. if not in with the pads where can i get some thanks
Re: brake pads help please
Posted: Sun Nov 17, 2013 5:11 pm
by suzukisteve
most of the time it will depend on the make of the pads you order. if its a decent make you may well get the retainer clip with the pads, if not ask for a brake pad fitting kit from your local factor as they should be able to get one for ya
Posted: Sun Nov 17, 2013 5:15 pm
by minibreaker
ill go to brakes international tommorow and see if they can help thanks
Posted: Sun Nov 17, 2013 5:34 pm
by Darrell
Brakes international do these, if these are what you mean..
- Aisin caliper - pad fittings.jpg (60.52 KiB) Viewed 6414 times
Ignore the prices it's an old screen save, but they are still listed.
Posted: Sun Nov 17, 2013 5:36 pm
by ferris
If its these your on about then this thread might help.
http://forum.suzukiclubuk.co.uk/vi ... =14&t=5395
Posted: Mon Nov 18, 2013 10:02 am
by ROBBIE
Is this one of those really important things that the brakes wont work properly without?
Posted: Mon Nov 18, 2013 10:14 am
yus.... fiddly little buggers! give me spanish brakes any day!!!
Posted: Mon Nov 18, 2013 2:04 pm
by ROBBIE
twiss wrote:yus.... fiddly little buggers! give me spanish brakes any day!!!
Glad mine is Spanish as well then, I haven't got them in mine
Posted: Mon Nov 18, 2013 5:18 pm
ROBBIE wrote:twiss wrote:yus.... fiddly little buggers! give me spanish brakes any day!!!
those clips aren't at all fiddly? you put them in then you put the pad in and jobs a good'un
I seem to have more issues with spanish calipers sticking as well, I've ended up with spanish ones on the front and jap on the rear and the fronts have been stripped and cleaned quite a few more times than the rear.
Posted: Mon Nov 18, 2013 5:27 pm
They're more fiddly than not having them there at all, and its another bit to loose if you're doing the work in the dark
I've only had 1 sticky caliper on mine in the 8 years Ive owned it... although ended up replacing it anyway as the bleed nipple snapped off!
