25 year old Suzuki Samuari
LoopyLoo
Post by LoopyLoo » Thu Nov 28, 2013 1:13 pm
Hi all, Newbie on the block and wondering if someone can help me with a problem. Daisy has started to die on me. She starts fine but when I slow down the revs just drop and she dies. Normally starts again straight away, but I have to keep the revs up or she dies again. Any ideas?
Re: 25 year old Suzuki Samuari
Post by dan_2k_uk » Thu Nov 28, 2013 1:15 pm
Hi and :welcome: to SCUK
What model/engine is this?
Post by twiss » Thu Nov 28, 2013 1:20 pm
I'll be willing to bet money that it's a 1.3 and it's the auto-choke!!!
Post by ScottieJ » Thu Nov 28, 2013 1:24 pm
twiss wrote:I'll be willing to bet money that it's a 1.3 and it's the auto-choke!!!
Or it's got a blocked fuel filter.
or
It's getting carb icing now the weather is colder, is the hot air feed (silver tube from the heatshield on the exhaust manifold to airbox) fitted? If so has the air box been switched over to the cold air setting?
Also if it's a 1.3 check the wiring to and from the fuel stop solenoid on the carb.
Post by Jordi » Thu Nov 28, 2013 2:19 pm
Welcome to SCUK.
As said what engine is it running?
Does it have the hot air feed pipe?
Has the air box been set for winter?
How long since it has a set of filters?
Post by ROBBIE » Thu Nov 28, 2013 5:31 pm
Hi :welcome:
LoopyLoo
Post by LoopyLoo » Fri Nov 29, 2013 11:53 am
Hi, she is a 1.3 and manual choke. I live in Cyprus and it is a little cooler now but ice is not not an issue!!
Post by Jordi » Fri Nov 29, 2013 11:54 am
Carb may just be knackered. Very common issue on 1.3s. Most people replace them with webber or SU carbs.
Post by ScottieJ » Fri Nov 29, 2013 12:09 pm
In that case I would start with the fuel filter and maybe give the crab a strip down and clean before swapping it out.
Post by Jordi » Fri Nov 29, 2013 12:14 pm
ScottieJ wrote:In that case I would start with the fuel filter and maybe give the crab a strip down and clean before swapping it out.
The crab? I think our esteemed leader means the carb.
