Thermoswitch for electric fans
Post by ScottieJ » Fri Jan 10, 2014 12:38 pm
Intermotor Part numbers, can source through most motor factors
I run the 50091 in my bottom hose however I am going to fit one with a slightly lower temperature rating as I find the first fan comes on a little bit too late
Part No.A/F Size Thread Temp °C (on-off fan1 / on-off fan2)
50100 29 M22 x 1.5 82-68
50101 29 M22 x 1.5 84-79/88-83
50250 29 M22 x 1.5 86-76
50012 29 M22 x 1.5 86-77
50090 29 M22 x 1.5 86-81
50120 29 M22 x 1.5 88-79
50295 29 M22 x 1.5 88-79
50296 29 M22 x 1.5 88-79/110-102
50271 29 M22 x 1.5 88-83
50272 29 M22 x 1.5 88-83
50275 29 M22 x 1.5 88-83
50217 29 M22 x 1.5 88-83/92-87
50091 29 M22 x 1.5 88-83/92-87
50212 29 M22 x 1.5 88-83/92-87
50213 29 M22 x 1.5 88-83/92-87
50216 29 M22 x 1.5 88-83/92-87
50221 29 M22 x 1.5 88-83/92-87
50219 29 M22 x 1.5 88-83/92-97
50240 29 M22 x 1.5 90-80
50110 29 M22 x 1.5 92-82
50111 29 M22 x 1.5 92-82
50112 29 M22 x 1.5 92-82
50113 29 M22 x 1.5 92-82/95-80
50218 29 M22 x 1.5 92-82/97-92
50170 29 M22 x 1.5 92-87
50200 29 M22 x 1.5 92-87
50210 29 M22 x 1.5 92-87
50211 29 M22 x 1.5 92-87
50220 29 M22 x 1.5 92-87
50230 29 M22 x 1.5 92-87
50231 29 M22 x 1.5 92-87
50235 29 M22 x 1.5 92-87
50260 29 M22 x 1.5 92-87
50270 29 M22 x 1.5 92-87
50280 29 M22 x 1.5 92-87
50281 29 M22 x 1.5 92-87
50285 29 M22 x 1.5 92-87
50290 29 M22 x 1.5 92-87
50215 29 M22 x 1.5 92-87/97-92
50011 29 M22 x 1.5 93-88
50102 29 M22 x 1.5 93-88/97-92
50035 29 M22 x 1.5 95-85/102-92
50130 29 M22 x 1.5 95-86
50030 29 M22 x 1.5 95-90
50033 29 M22 x 1.5 95-90
50061 29 M22 x 1.5 95-90
50062 29 M22 x 1.5 95-90
50160 29 M22 x 1.5 95-90
50092 29 M22 x 1.5 95-90/100-95
50174 29 M22 x 1.5 95-90/100-95
50104 29 M22 x 1.5 97-92
50282 29 M22 x 1.5 97-92
50103 29 M22 x 1.5 97-92/101 -96
50214 29 M22 x 1.5 97-92/102-97
50190 29 M22 x 1.5 100-95
50195 29 M22 x 1.5 100-95
50196 29 M22 x 1.5 100-95
50197 29 M22 x 1.5 100-95
50198 29 M22 x 1.5 100-95/110-105
50000 29 M22 x 1.5 103-98
50013 29 M22 x 1.5 103-98
50014 29 M22 x 1.5 103-98
50191 29 M22 x 1.5 120-115
then you just need to find an m22x1.5 hose adapter for 25mm hoses
Re: Thermoswitch for electric fans
Post by turbo-tom » Fri Jan 10, 2014 7:29 pm
Nice info cheers for sharing that mate :D
suzukisteve
Post by suzukisteve » Fri Jan 10, 2014 9:31 pm
I stock intermotor at work. if I don't have it on the shelf I should be able to get em direct from the supplier :thumbup:
pickle power!
ianedwards
Post by ianedwards » Sun Jan 12, 2014 3:25 pm
Does any one know how to test a switch?
I've fitted one, decided to try so filled the hose up with water from the kettle expecting it to switch, but no luck. Is it I'm just not getting it hot enough for long enough or is it faulty?
Ian. :)
Post by twiss » Sun Jan 12, 2014 3:27 pm
usually best to have the stat switch in a pan of heated water...
use a multimeter and test the resistance and continuity as it heats up
Edit: I usually just test on the truck though...
ianedwards
Post by ianedwards » Sun Jan 12, 2014 4:37 pm
Yep, test as follows
Took the switch out, tested resistance = 1 (closed)
Placed in pan of water on the hob, started heating pan.
While heating before the water started bubbling, tested resistance = 0 (open)
Took out of water to cool down, tested resistance = 1 (closed)
Double checked So I'm confident it works
Cheers :salute:
Ian. :)
Post by twiss » Sun Jan 12, 2014 4:39 pm
good stuff :)
don't want your fan stat packing up!
