my suziki sj 410
sam_richards_231
my suziki sj 410
Post by sam_richards_231 » Mon Jan 13, 2014 9:04 pm
hi whats the best way to get rid of these rust spots on my suzuki sj410 any help on this thanks sam
Re: my suziki sj 410
Post by dan_2k_uk » Mon Jan 13, 2014 11:44 pm
Chop it all out and weld in repair pieces if you have access to a welder.
From the looks of the front area of the rear arches when you start poking round the body mount area its going to go right through to behind the drivers seat.
dndnk
Post by dndnk » Tue Jan 14, 2014 7:58 am
chop it out and back on arches give your self a virtual lift why your at it
SJ 410 currently off road waiting to leap out of hibernation.
Please visit wifes web site http://www.apassionforcakes.co.uk/index.htm you might even find a zuke on there :-)
sam_richards_231
Post by sam_richards_231 » Tue Jan 14, 2014 8:11 am
Ok then ill have a look at doing that as i got a welder and all that so ill have a fo then thanks you lads
Post by dan_2k_uk » Tue Jan 14, 2014 11:16 am
Here's a little guide for the virtual lift. http://forum.suzukiclubuk.co.uk/vi ... =10&t=8046
Also I have photos in my build thread of some of the other areas. http://forum.suzukiclubuk.co.uk/vi ... 5&start=20
Post by twiss » Tue Jan 14, 2014 12:51 pm
best to get the grinder out and find out where the rust ends and the good metal begins!!!
what part is the first pic?
for the underside of the rear footwell i ended up chopping most of it out and replacing with some 90* bent sheet
the back of the arch next to the fuel tank might be doable with 1 or 2 plates
i'd probably take the tank out first though just to be safe!!!
sam_richards_231
Post by sam_richards_231 » Tue Jan 14, 2014 5:15 pm
ok then twiss and ye mate im guna take the tank out befor i do any welding mate as dont fancy going up in flames really
