sj410 wheels
sam_richards_231
sj410 wheels
Post by sam_richards_231 » Wed Jan 15, 2014 10:27 pm
whats the best off road tyres and rimes for the sjs as i guna get some new 1s for it ? thanks sam
Re: sj410 wheels
Post by Jordi » Wed Jan 15, 2014 11:34 pm
Depends how much lift you run and what size tyres will fit.
sam_richards_231
Re: sj410 wheels
Post by sam_richards_231 » Wed Jan 15, 2014 11:40 pm
what would ypu lift it to jordi and what size tyres would you have mate as i new to this so im just lerning still mate
Re: sj410 wheels
Post by Jordi » Wed Jan 15, 2014 11:50 pm
A lot of us run minimal lift, 2" ish, and have done a virtual lift (cut the arches out). I run 33s, as does Scottie and Ferris. Dan is on 31s but is going to 33s.
On standard springs you can go to 235/75s quite easily. I did have 31s on standard springs with just a virtual lift.
All depends on budget and if you want to go virtual lift, body lift, lift springs, spring over axle. 31s are a good size on an SJ.
Also depends on gearing, when I had my 31s on standard gearing it was painfully high geared.
Re: sj410 wheels
Post by dan_2k_uk » Wed Jan 15, 2014 11:55 pm
If you don't have the confidence to cut the arches and bulked out I would go for some 2 inch lift springs and some 31s.
My current setup has done me proud and handles well on the road still.
sam_richards_231
Re: sj410 wheels
Post by sam_richards_231 » Thu Jan 16, 2014 12:01 am
ok then lads ill have a look at that then as im not sure whats on it at the moment really as i had it with most of the work done on it really how would i find out what it has been liffted and got on my sj thanks sam
Re: sj410 wheels
Post by Jordi » Thu Jan 16, 2014 12:09 am
Easier way to measure the lift is probably to measure the clearance between the ground and the bumpers and compare it to someone on standard springs.
Re: sj410 wheels
Post by dan_2k_uk » Thu Jan 16, 2014 12:09 am
Just upload some decent photos of the suspension.
sam_richards_231
Re: sj410 wheels
Post by sam_richards_231 » Thu Jan 16, 2014 12:15 am
ok then i will have to take some photos and put them on tomorrow then mate as its too dark na to do it
sam_richards_231
Re: sj410 wheels
Post by sam_richards_231 » Thu Jan 16, 2014 7:32 pm
here is a photo of the hight of the sj mate i not sure if it isnt a good enough photo tho for you
