Wiring diagrams
Re: Wiring diagrams
I just use "photoimpact 10". Only because it came pre-installed on my last PC.
Re: Wiring diagrams
Just had a look at that fuse. I've added it as the acc supply from the ignition switch to the radio and ciggie lighter.
- santanawiringdiagram.jpg (499.73 KiB) Viewed 62030 times
Re: Wiring diagrams
Vitara SE1600 wiring diagram - From the workshop manual (1994 Print)
- Vitara wiring - Carb.jpg (1.82 MiB) Viewed 55428 times
Re: Wiring diagrams
Vitara SE1600 wiring diagram (injection model) - From the workshop manual (1994 print)
- vit inj layout.jpg (533.1 KiB) Viewed 54030 times
- ajowin
Re: Wiring diagrams
I'm looking for the wiring diagram for the heating control panel for my B reg SJ410. If anything a photo showing the wire connection to the levers would be really useful. The wire connectors are circular!
We be enjoying our SuziB!
Re: Wiring diagrams
The only part of the heater control panel that has electrics is the fan speed switch, the rest are cable operated mechanical linkages. What is the problem with it?
Re: Wiring diagrams
Are you after the cable linkage diagram rather than the wiring diagram ??, sounds like it
Found this for a 83-84 model. The dash with the rotary speed control.
- 1983-4 model.jpg (135.17 KiB) Viewed 50618 times
Re: Wiring diagrams
Does anyone have a wiring diagram for '82s Samurai? Its different from the later ones, has a completely different fuse box.
Re: Wiring diagrams
Is it the type with just 4 cylindrical fuses.
I have a diagram in the workshop manual, although the join across the pages is not very clear.
I could try to photograph it and join it.
