Spark problem
Spark problem
Hi all i have a problem the coil is working but no spark from ht leads could it be the Condensor.
Re: Spark problem
You say the ignition coil is working?
How have you tested it?
If the coil is working correctly, and the distributor is actually turning round, you should definitely get a spark at the plugs
Unless all of the ht leads had failed at once...
Re: Spark problem
ht leads are new cap is new to test the coil i put a volt meter on it
- Ladaman
- Suzuki Guru
Re: Spark problem
On the output?
Have a look at this, it might help.
http://www.aa1car.com/library/ignition_coils.htm
Or try this from the Suzuki SJ manual.
- Capture.JPG (53.07 KiB) Viewed 6656 times
- Ginger_boy
Re: Spark problem
Where are you not getting the spark, I'm assuming at the plugs. If you have just changed the dizzy cap make sure that the carbon brush is contacting to the rotor pull it out a little. Had this on a very old maestro once
Re: Spark problem
will try that sat thanks
Re: Spark problem
put on a new rotor and points too, this way you won't have too many problems in the future, and it's cheap, just make sure you set the correct points gap
