Break carrier
Break carrier
Hallo I'm new to the forum can anyone help I got a suzuki sj413 samurai 1989 I needed new break pads but I broke the bolt on the right hand side I need a new carrier for it but can't find one anywhere any help is grateful. I'm at a losed end!! Thank you very much stuart.
Re: Break carrier
Which callipers do you have? Can you post a picture, someone might have spares.
Is it not possible to remove the broken bolt?
Re: Break carrier
I will do I got my mechanic on it he tried to drill it out but hit a hard bit I will take photo and get back to you thank you
Re: Break carrier
I've got a few spares from the axles I'm splitting, so should have bolts, calipers & mounts, let me know what you need.Themils wrote:I will do I got my mechanic on it he tried to drill it out but hit a hard bit I will take photo and get back to you thank you
Re: Break carrier
It's the cylinder carrier right hand side I need thank you tryin to upload photo but can't do it
Re: Break carrier
Here's a photo
- image.jpg (1003.79 KiB) Viewed 6796 times
- image.jpg (672.45 KiB) Viewed 6795 times
Re: Break carrier
That's probably the most common fitted to an SJ , I'm sure the guys will have spares.
Don't know if this will be any use on refitting http://brakeparts.co.uk/#!/shop/SUZUKI/ ... rs/BCF1406
Re: Break carrier
That's no way to treat your workshop manual
to the club
to the club
Re: Break carrier
