- IMG_2927.jpg (330.93 KiB) Viewed 6973 times
Project KJA
- ianedwards
- SCUK Addict
Re: Project KJA
tank touching the dif
Ian.
Ian.
- ianedwards
- SCUK Addict
Re: Project KJA
bed needs to go up,
Ian.
Ian.
Re: Project KJA
Why did you move the tank?
- ianedwards
- SCUK Addict
Re: Project KJA
the ram needed to go where the tank was, so I had to move it back a bit, but as it was spoa, it wasn't a problem.
Ian.
Ian.
Re: Project KJA
What a nightmare after all the work that's been put into it.
- ianedwards
- SCUK Addict
Re: Project KJA
Not really, it is a pain but im happier with it lower, looks better. And probably will feel nicer to drive.
I've got some 75 x 50 box now, so all ive got to do is cut bits to go on the 6 bed supports and cut the rear tipping points off and add the box In between, will probably make it all to bolt on, will make less mess.
I've got an idea for another bed in the future so if I make the brackets bolt on, I've only got to build another frame,
Ian.
Ian.
- ianedwards
- SCUK Addict
Re: Project KJA
just got to lift the tank, bit of paint, put the lights back on and job done.
Ian.
Ian.
- donkeychomp
Re: Project KJA
Re: Project KJA
So when do we all get to see this creature in the flesh?
