wheel bearing
tuskar
wheel bearing
Post by tuskar » Fri Mar 13, 2015 9:48 pm
I have a 2000 GV diesel. Was thinking of greasing the wheel bearings , as I am sure grease is shot after 15 years.
Do I need that special Suzuki bearing tool to dismantle or is there some alternative method of doing it ?
Re: wheel bearing
Post by Anton » Fri Mar 13, 2015 11:05 pm
If you don't mind me asking, but if you're going to the trouble of dismantling your front axle, why not replace the bearings? After 15 years, they probably won't have a great deal of life left in them, and they're not that expensive.
Saves you having to do it all again a couple of years from now...
Re: wheel bearing
Post by Darrell » Fri Mar 13, 2015 11:39 pm
I would leave them alone...
You need a special tool to remove the hub nut and then the bearing is a sealed unit (1999-2000).
Same tool is needed for the 2000 onwards ,but the hub is the bearing, so needs replacing as a unit when required. It is open on the nut side but you won't get much grease in it.
Yours should be the early type anyway ;)
Diagrams of course.........
1999-2000 GV.jpg (213.03 KiB) Viewed 5275 times
2001 onwards GV.jpg (178.82 KiB) Viewed 5275 times
Re: wheel bearing
Post by Anton » Sat Mar 14, 2015 1:19 am
Yikes! I was assuming that the job would be similar to my SJ - that is, not difficult. Doh! I should know better than to ass.u.me anything!
Re: wheel bearing
Post by donkeychomp » Sat Mar 14, 2015 2:14 am
That looks all to familiar...it is a bastard of a job but if they aren't an issue leave them alone. If they are fubar then it's a blow torch and lots of swearing.
tuskar
Re: wheel bearing
Post by tuskar » Sat Mar 14, 2015 6:38 am
Thanks for all the quick replies guys. Will leave alone and deal with it if problem arises.
