Water leaking on Passenger side
courior
Post by courior » Sat Mar 28, 2015 5:06 pm
Hi all.
Got this rain water leak on the passenger side but just cant figure out where the heck its coming from.. it even gets inside the glove box through the split of bottom to top half (old skool circle vent dash)... Ive sealed around the window hinge (this solved it for the drivers side) and the window surround is dry so not from the window... number one on my hit list is the area where the fold down window would seal on the bulkhead but on the side where the door touches. Anywhere else to look?
Courior
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
Re: Water leaking on Passenger side
Post by ScottieJ » Sat Mar 28, 2015 6:06 pm
Check the plastic drains from the grill on the scuttle panel to the bulkhead in the engine bay arent blocked up.
Post by twiss » Sat Mar 28, 2015 6:07 pm
He's already cleaned them both out and made a cover for the scuttle vent
Martin86
Post by Martin86 » Sat Mar 28, 2015 6:43 pm
I have this problem too! Dashboard out I reckon :thumbdown:
courior
Post by courior » Sat Mar 28, 2015 11:37 pm
screw that... ill just silicone seal the glove box and put more sealant where i think it might be leaking and hope... or.. when it stops raining i will use a hose pipe and direct water in different places till i re-produce the leak.
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
Post by ROBBIE » Sun Mar 29, 2015 4:25 pm
courior wrote: i will use a hose pipe and direct water in different places till i re-produce the leak.
Did all that on my old one, even had the dash out, me in the driver seat, mate in the passenger seat and another mate with the hose pipe outside and still never found where the water was coming in :er: :argh:
