Water temperature + stalling
adib
Post by adib » Sun Mar 29, 2015 8:36 am
I have a 1.6 16v Vitara, which sometimes, when the engine is warm it doesn't keep the idle. It dies. It doesn't happen every time and I could not work out a pattern. After it acts out, if you keep running it, the symptoms disappear, only to come back later. Has anybody else encountered this issue? How did you fix it?
And another thing, whenever I put my foot on the gas, the water temperature indicator goes to zero, as soon as I lift off it comes back to the normal indication. Any ideas? I am guessing it is an electrical gremlin with the temp sensor.
Behaviour:
https://www.youtube.com/watch?v=YCotZVouhMk
Rhinoman
Re: Water temperature + stalling
Post by Rhinoman » Sun Mar 29, 2015 8:40 pm
Sounds like a grounding issue, does the starter spin up OK?
adib
Post by adib » Mon Mar 30, 2015 4:37 am
Yes it does, it starts without any issues, and it runs as well. Just from time to time it starts acting out.
The temperature thing is constant.
Rhinoman
Post by Rhinoman » Mon Mar 30, 2015 1:07 pm
I would start working through all the ground connections undo them, clean them and then reassemble with a little Vaseline to keep moisture out. You have a bad connection somewhere.
adib
Post by adib » Tue Mar 31, 2015 4:17 am
Will look into it, thanks!
