out of controll
Re: out of controll
Post by ScottieJ » Tue May 19, 2015 4:49 pm
No that gap between the spring bush eye and "military wrap" second leaf is fine.
Shorten the shackles/re fit standard ones then adjust the steering box play and check everything else.
gratton
Re: out of controll
Post by gratton » Tue May 19, 2015 5:28 pm
Thanks how do I adjust the steering
Re: out of controll
Post by ROBBIE » Tue May 19, 2015 5:33 pm
While you have the shackles off, Id do the bushes as well
gratton
Re: out of controll
Post by gratton » Wed May 20, 2015 6:50 am
Just two more things I do have a wobble when I pull off but spots after ok around town just when I pull off and whats the best front and back seats I can put in the sj.
Re: out of controll
Post by ROBBIE » Wed May 20, 2015 9:49 am
Up front whatever you can make fit, as for the rear I threw mine away :D
Re: out of controll
Post by ScottieJ » Wed May 20, 2015 11:55 am
gratton wrote:Thanks how do I adjust the steering
http://forum.suzukiclubuk.co.uk/vi ... =15&t=3310
gratton
Re: out of controll
Post by gratton » Wed May 20, 2015 12:48 pm
Cool thanks swapping my bucket seats for some Ford seats now the wife might stop bugging me
Re: out of controll
Post by dan_2k_uk » Wed May 20, 2015 11:03 pm
If the steering box is more worn in the centre of its travel than the ends you have to me careful not to adjust it too far or it will be tight at lock.
gratton
Re: out of controll
Post by gratton » Fri May 22, 2015 8:28 am
Steering is all good now if I kick the front right wheel it makes a hollow sound I do have a spear axle in my shed it's off a sj but it's not the same as the one on my new sj it has wheel lock in the centre cap will it fit :er:
Re: out of controll
Post by ScottieJ » Fri May 22, 2015 9:43 am
:er: what do I you mean it makes a hollow sound?
What did you change/adjust to sort the steering?
All parts on all Sj axles from the knuckle seal outwards are interchangeable, the only bits that are different between models are the shafts, CVs, axle cases and diffs, but depending on the model said me of those can be swapped as well.
