Oil on floor
Re: Oil on floor
rocker cover gasket.. or maybe dizzy oil seal.. or fuel pump seal.
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
5 speed box
1.5" Shackle Lift
Daymaker led lights
Re: Oil on floor
Engine oil or gearbox oil?
Could be gearbox input seal?
- donkeychomp
Re: Oil on floor
It's always the dizzy seal...they've failed on every zook I've owned.
Re: Oil on floor
it looks engine oil going to have a look at dizzy seal tonight thanksJordi wrote:Engine oil or gearbox oil?
Re: Oil on floor
Looks like it's coming from here
- FB_IMG_1433955350536.jpg (61.17 KiB) Viewed 8761 times
- FB_IMG_1433955345694.jpg (21.19 KiB) Viewed 8761 times
Re: Oil on floor
That's your timing inspection hole. You can buy a plug for it or you can just bung it up with something.
Re: Oil on floor
It only started when I got back from a day out off roading I did go in a river up to the windscreen lol
- Tramp
Re: Oil on floor
Mine leaks a little from here, and out the hole underneath - after wading when off reading, I'm not 100% cetain but I think it means your crankseal has gone or your gearbox input seal, can you tell what sort of oil it is?
