1991 Suzuki Samurai build
gp7186
Re: 1991 Suzuki Samurai build
Post by gp7186 » Sat Oct 26, 2013 11:22 pm
dazerede wrote:Wow u have done a realy nice job on.this sj
All I need to.do is paint the backplates and jobs a gooden
Thanks I have rebuild kits for both sides as the swivel seals are leaking and kingpin bearings showing some wear so I will strip everything down and paint e, t, c . Thats my next job along with the exhaust
gp7186
Post by gp7186 » Mon Nov 04, 2013 3:05 pm
Managed to get both sides rebuilt with new wheel bearings, half shaft seals, kingpin bearings and swivel seals also cleaned and sprayed everything up
dazerede
Post by dazerede » Mon Nov 04, 2013 6:41 pm
Looks good.mate that's what I.need to do on my.front axle bearings
4” calmini lift kit :)
chazz_543
Post by chazz_543 » Mon Jul 20, 2015 10:19 pm
Hello mate I would like to know how your toyota prop is working out for you. I have unparallel prop angles and hoped this mod would help. I am thinking front and back with a notch cut out the chassis at the front.
gp7186
Post by gp7186 » Tue Jul 21, 2015 9:46 am
Well i dont really use it that often but i have no vibration coming from it and it made a massive improvement to the way it drives, well worth doing
Cheers gaz
chazz_543
Post by chazz_543 » Tue Jul 21, 2015 4:09 pm
Thanx for getting back to me I will have a look in to it.
gp7186
Post by gp7186 » Mon Sep 28, 2015 12:08 pm
Time for a little update i think in the last month ive replaced:
- Timing belt, tensioner and water pump
- Front wheel hub bearings and seals
- Rear wheel bearings and seals
- General engine service oil, filters e,t,c
- Wheels replaced for steel 15x7 rims refitted my original 31" tyres
- Oh and a damn good clean
r-nottz
Post by r-nottz » Mon Sep 28, 2015 12:25 pm
This thing is damm tidy, fair play mate.
kevinsantos
Post by kevinsantos » Thu Feb 04, 2016 9:53 pm
hello. I was seeing your build and i need some help on the mounts. do you have any PDF or something with measurement like a blueprint. that will help me alot :). thanks
gp7186
Post by gp7186 » Fri Feb 05, 2016 9:31 pm
Sorry but I thought I did have some drawings but I can't for life of me think where I have put them perhaps I have thrown them out but more than likely I have them in a safe place so safe I can't find them myself but il keep looking. To be honest though the brackets are pretty self explanatory if you put a spring in place and make a template.
