Cheers for the trailer offer tony but then i'd have to pay extra on the ferry
It should be all good I swapped some rear side gears over from an old sammy diff into one of my good spare 410 front diffs
it's the first time i've built a diff so i hope i got the bearing preload correct
I just counted the amount of turs it took to remove the bearing retainers and re fitted them with the same amount of turns
It feels all good! (I hope) I'll be taking a spare prop and extra UJ, a spare alternator and CV
I also replaced a front wheel bearing last night and fitted some tie-down points in the rear bed for some storage boxes to go in.
My fuel pump turned up today so tonights jobs are to fit that and the franken diff and I should be good to go
